Hi, all!! :)
I've replaced teh spark plug twice and the plug wire once and am still getting this error.
Does anyone have any other ideas on what to check?
Thanks in advance,
- Bugged
20V GTRS
SMG said:
This is a dumb question, but could you be mistaking cylinder 1 for cylinder 4, and vice-versa?
Plugs and wires are the only things I know of that cause misfires.
He may not be mistaking cyl 1 for cyl 4, It could be a case of the ECU coded wrong. My roommate (VW tech) has seen VWs with that problem. I would say swap the outter 2 spark plugs with each other and see if the error follows.
That's weird, I never would have thought that was possible.
Just put new plugs and wires on the two outer ones, and you should be good to go :)
SMG
So it's misfiring, eh?
At night, when it's nice and dark, open the hood and start the car. Look at the coil pack. See any arching? Probably will. ;)
-Des
180 Degrees out of faze
To help you see the arching, mist a little water over the coil and wires. Then see if there is any difference in the idle.
