Yes, I was referring to the complete throttle body assembly. I did not open it, just gave a good cleaning before installing, so there is no oil/goop buildup around and on the
butterfly valve.
The Meyle relay is a simple relay with 4 pins: , 2 coil pins and 2 pins that are switched on/off, hopefully they got that right. If need be, I can get a different make from a different supplier at some other time.
I did get the OBDeleven, I still need to install the software to me cell phone and "play" to see what I can do/see on the Bug and the Golf.
I will test the car today again, if all still good, I will reassemble the rest of the parts/panels that I took off to be able to do the work.
Again, thank you for your guidance.
butterfly valve.
