@billymade , thanks for the testing procedure. Do you know what #1 O2 sensor values it refers to that I test for, after the physical inspection?
This evening I found the spare ECU I had, and put the battery on charge. I'll dig in deeper tomorrow. I think I'll do that coil block ground patch as it looks easy and straightforward, and since I'm disconnecting the battery anyway to "reset" the ECU, I may as well take it out, and the battery tray, and wire that ground post to the coil block ground line.
So the ECU I have is a 06A906032KB, which is for a 2.0L Beetle, but a convertible with manual tranny. The unit in my car is a 06A906018JE, specifically for California emissions, so unless they were all like that I may have a California car.
So, given the spare ECU is for a manual, I don't think the car would be driveable with it, but it should be close enough to see if the misfire persists. If it goes away, then that points to a bad original ECU. If it persists, then I can eliminate the ECU as the culprit. Funny to think the PO of the '03 1.8T Auto trans Beetle I got for my son was using this ECU to fix that car.
So, I'll reset it's own ECU. See if that makes any difference (not optimistic). Then I'll do the ground wire patch for the coil block, test again. Then I'll swap the ECUs just to see what happens.
These ECU's are so rare and expensive I feel I should rush out and find/buy an early 2000's stick-shift 2.0L convertible to match it so that I can have a spare down the road for when it eventually fails
