I want to clear these codes and keep them cleared. I checked and replaced the vac lines to the purge valve and cant find any leaking lines. Finally decided to remove the Secondary Air Injection Pump. It doesnt run and I really dont need it. I blocked the lines. Still getting these two codes after I clear all codes. Is there a way to trick the ECU or is there someting else that I can do?
Thanks
Thanks
