In another thread I mentioned I had this code, but it was more to do with the warranty, which my car escaped, so I thought I'd start a new one. Tonight, while idling at sonic, the car jumped or shook and I quickly turned it off. It started fine and didn't do it again. I read most the threads regarding this code, but I didn't see this symptom. Here is the read:
P0420
Catalyst system below efficiency threshold bank 1
Explanation faulty catalytic converter
Probable cause
1 rich air/fuel ratio
2 air leak near HO2S (heated oxygen sensor)
3 faulty fuel control HO2S (heated oxygen sensor)
Could a bad oxygen sensor cause a spastic idle for a second or two and then even out?
Thanks!
Sandy
P0420
Probable cause
Thanks!
Sandy
