Hello,
Wife's car had check engine light come on, and it was a P0420 code. Oxygen sensors were replaced, waited a couple weeks to see if the CEL would go out, and it did not. Today, the car has developed an occasional misfire in idle and sometimes at slow speed, but at highway speeds, the engine seems to run fine. After a short drive on the interstate just now the car appears to be back to running normally.
Symptoms while driving slow and idleing were occasional bucking (only while driving obviously) and flashing CEL for misfiring. She wasn't far from home so she went back and parked it. She's planning to head to a parts store to have the codes run again tomorrow, but no dealers or shops will be open until Monday.
Any ideas on how the converter may be affecting this misfire? Partially clogged maybe? I told her this may be the problem and to try to take it to the interstate for some higher rev's to see if it can clear out the exhaust and like I said, it seems to be running normally now...so a new catalytic converter is in the future most likely. Any insight is appreciated if others have had similar experiences, as I'm 1500 miles from the car at this time due to work. The car only has problems when I'm not around!
