Oh lord... will a dealer be able to tell which one of the 10 possibilities is causing the check engine light? lol.The infamous P0420 code rear's it's ugly head again...LOLGood luck chasing that ghost fella.....and let us know what you find.
That's why I hadn't reflashed mine at the Stealership, heck I can drive around with a pesky little light that comes and go's all the time than to pay 250. It would be nice to know if your ECU has been reflashed already to the latest software upgrade, does anybody know if that can be done with the vag-com ? any cyber smart folks out there?My 1.8t had the P0420 code early in its life. At the time the dealer replaced the catalytic converter, which was likely dropped at some point before it was installed as it has a large gumball piece of the monolith break off and get caught between the 2 converter sections and sounded like the car had marbles in the exhaust.
I believe at some later date there may have been a ECU upgrade that addressed cold start stalling as well as the "phantom" P0420 codes.
Many of the cars that have P0420 codes may have had exhaust leaks, cracked welds on O2 sensor bungs, questionable O2 sensors and could have questionable catalytic converters, but what I have found is rarely is the catalytic converter the cause.
If you might be still covered under warranty and/or I think the 2.0L cars may have had extended coverage for the catalytic converters or an emission recall campaign?? Then you could speak with the dealer, but they will see you everything they can. You can purchase a decent aftermarket catalytic converter/downpipe/flex joint assembly for around $250, so keep this in mind before you deal with the stealership and get your wallet cleaned out.
If you do not go the dealer route, suggest you clear the code and see how long it take to come back.
Likely the code will not come back for a fair amount of time. Usually they only trigger when driving on the highway and usually on long downhill grades where you are on the throttle very lightly and/or coasting.
Many other makes and models had similar problems and the solution for many manufacturers is to slightly widen the window for the P0420 code to be triggered as many times the window was too narrow and the ECU code was too sensitive.
Again, you could possibly have the ECU reflashed at a dealer or good Indy, but this likely will be close to $250 at the dealer?
It is a 2005 with around 93k miles on it. How would I go about finding out if the cat is still covered under the emission recall campaign?My 1.8t had the P0420 code early in its life. At the time the dealer replaced the catalytic converter, which was likely dropped at some point before it was installed as it has a large gumball piece of the monolith break off and get caught between the 2 converter sections and sounded like the car had marbles in the exhaust.
Call a dealer and give them the VIN.How would I go about finding out if the cat is still covered under the emission recall campaign?
Mileage drop would not be caused by the light and the code.It is a 2005 with around 93k miles on it. How would I go about finding out if the cat is still covered under the emission recall campaign?
I cleared the code a few times and it does take a few days to come back, problem is I noticed a significant drop in gas mileage since this light has been coming on as well so I wanna get it fixed for that reason.
