2005 GL 2.0
120K
CEL on continuously
I am way overdue for my yearly inspection here (Texas) and would like to solve this problem(s) asap. I just had the car scanned and it came up with these two codes. The P0118 code deals with the engine coolant temp high circuit. Does this mean the car is running hot and/or I need to add coolant? The coolant seems to be within the low/high marks on the reservoir. Timing belt, water pump, etc., were all replaced at 80K
As far as the P0420 code...I noticed a few weeks ago that one of the hoses which connects to the secondary air pump seemed broken at the point of connection. It's connected, but it seems like it isn't seated very securely...could this be a cause of the P0420 code? Additionally, sometimes after driving around town for 20-30 minutes...then going grocery shopping, etc., the car is very hard to start...like it's misfiring. This only lasts about 20 seconds, and it never happens when the car is cold or has been driven more than 30 minutes.
Any help would be appreciated.
120K
CEL on continuously
