P0455 help
14K views 7 replies 4 participants last post by  red99
16839/P0455/001109 - Ross-Tech Wiki
Well, you have your work cut out for you; evap system leaks, could be tested with a smoke machine or pressurizing different areas to find a leak. The most common issues; seem to be the gas cap seal and the p80 purge valve, which you have replaced. Here is a thread with info; that might help you understand the system and how it works, possible ways to start narrowing down your leaks.
I'm afraid; there are no "magic bullets" but troubleshooting the problem, would require a step by step process of elimination. Look at the videos from VW; they show checking each section of the system for leaks, in a methodical process.
http://newbeetle.org/forums/2-0-lit...r-gas/121882-evaporative-system-status-incomplete-need-help-emissions-test.html
Testing and inspection; without a factory VW scan tool:
http://workshop-manuals.com/volkswa...nent_information/testing_and_inspection/with_manufacturers_scan_tool/page_4488/
