1 - 1 of 1 Posts
Good morning. I'm sure I did this. I was having the shift solenoid problem so I bought the shift solenoids and a service kit. (Fluid filter gasket). I removed the valve body and replaced the solenoids. reinstalled the valve body and put in 2.5 liters of fluid. ran it through the gears, all seemed OK. I shut the car off and put in the remaining fluid (an additional 3.5 liters). This was done with the front of the car on jacks. I took the car off the jacks and removed the fill kit hose and started to drain what I thought was excess fluid. When I started the car I got the check engine light and all of the shift indictor lights are lit When I put it in gear it slams into gear. I used my generic OBD II diagnostic tool to get the codes. I got P0715 and P0720. Anyone have any ideas? I did verify that all the connections are good inside the transmission.
06 Beetle, 2.5l and 09g transmission.
Thank you for any help.
1 - 1 of 1 Posts
