Why did you use the starting fluid? What are you using to scan with? Its not a code that I see on my usual code lookups for VWs.
I used a VEEPEAK OBDII Diagnostic Scanner and OBD Fusion on my iPad. I cleaned out the moisture in the air intake, checked all the vacuum hoses, cleared the code and drove like 40 miles round trip today; no check engine light.
Automotive design Font Material property Electric blue Personal protective equipment
So, what is the current status of things (problems, error codes, cel’s, etc.)? Have you done any testing of secondary air injection issues and diagnosed any problems? What trouble code are you getting?
