Part of my convertible top is busted and I need to know what it's called.,.any ideas?
2559 Views 3 Replies 3 Participants Last post by  Lorrix
Hey--
I'm going to do the best I can to describe this part that broke off my convertible top. It is a clip of some sort that slides along as the top opens and closes, to keep the top tight when it's closed.prevent bunching when it's open. It's riveted/connected to a piece of elastic.
This is on the drivers side of a 2003 NB. It's got a whopping 16k miles on it.
The top goes up and down no problem--but it's going to bug me. Any ideas what this part would be called, and if it could be replaced without replacing the entire top?
I will try to attach a pic, but judging by how my day is going, I will probably break that, too.
Any help you could provide would be greatly appreciated.
Thank you,
Nicole
I can't help on the id of the part but you could go by your local VW dealer and I'm sure they can get you the parts you need (be sure to have your VIN #). You can also; look up parts online:
check out:
VW Parts | Volkswagen Parts
Volkswagen Parts 2Go | Genuine VW Parts | Up to 25% Off
or vw's online e store:
Volkswagen National eStore
It looks by the picture that you are looking for the guide that slides the headliner back and forth as you lower and raise the top. It has a couple of cords that attach to the clip and go through guides. Depending on the part or parts that are broken sometimes its easier to just replace the broken pieces, but you will have to purchase the complete guide, cost is about $40.00 at your dealer, best to go with your VIN as suggested above as there are two slightly different versions of this clip but I think you have the early version.
If correct you are looking for part number,
Left side 1Y0 871 341
Right Side 1Y0 871 342
Later versions are the same part number but add a "B" to the end.
Look at this link from ECS.
Search 1Y0871341 - 1Y0871341 - GUIDE - ES#325451
Hope this helps...
K
That's a huge help...thank you so much for taking the time to respond, it's much appreciated!
