My wife has a 2005 Beetle Convertible. We bought it used a few years ago. The passenger side front window’s switch worked but it loose in the door. I replaced it with a new one. A few months it worked great and now the window will not go down. How do I check to see is if the window motor is bad? What else could it be? I hate to buy a $300+ window motor and that not to be it.
First things first, have you checked the connection to the switch? It's possible that it was loose when you changed the switch months ago. Also, the clips on the electrical plugs that hold them secure sometimes break which could cause the plug to come loose over time.
I have checked the connection it was good. I even changed back to the old switch and still nothing.
