21 - 31 of 31 Posts
· Registered
Discussion Starter · #26 ·
So I took the door skin off and nothing appeared obvious. But I did discover that the lock does not work on that side either. I can hear the click when I unlock on that side, but when I lock the car, the passenger side does not lock. Both switches have light to them, but neither works for their intended purpose
· Registered
So, you took the door panel off and inspected the door with the trouble code?
The code was for the passenger side door control module.
You might unplug that door lock module and see if the convertible top and other side door start working again?
If operation is restored; then that may indicate the unplugged part is defective and causing things on the communication bus, to go down.
· Registered
Well, that is the point of a process of elimination; start unplugging things, one by one, to isolate, remove things and check to see the results. It would make sense, to start with the passenger side; the parts that has the trouble code, in that case, was the door lock module?
· Registered
· Registered
I, unfortunately, do not have anything that is android. The apple model is quite a bit more. And that is what I figured with Amazon being my best option to be able to return it if it doesn’t work. I have all Apple products and one chrome book.
yeah. Coverage for apple services is a bit less. But they provide excellent services according to my experience. If you buy from amazon return policy is flexible and more clear. You can also directly buy from the apple store where apple provides its free services and apple return and refund policy.
21 - 31 of 31 Posts
