I have a 2004 nbc that has a passenger window issue ,it was working fine till today now it will only go half way down.I have already replaced the drivers regulator after that window fell down inside.does anyone have an idea what could be going on,:confused:
this car is driving me nuts
You might try searching the forum for a convertible reset procedure; see if that works, if not.... then see if your regulator needs replaced. It also wouldn't hurt to have the car scanned for trouble codes; with a Vw compatible scanner, it will typically read codes about failing parts and the dying regulators usually throw a code.
thanks for the reply,I was hopeing not to hear replace the regulator,but that was my frist thought also.I didn't know it would throw a code,I will check it out and let you know.
I just did the other side and set the up and down limits with the key, I wonder if that had anything to do with it.
