Have it scanned and let us know what the codes are.
A standard OBDII scanner may or may not show the proper codes. In either case you will need a VAG com to reset the seat belt codes.Take the car to the local Autozone and have it scanned for codes.
The codes are the cars computer telling you what is wrong.
Another link regarding Airbag light:
http://newbeetle.org/forums/questio...-re-seatbelt-buckle-causing-airbag-light.html
Seems like a very common issue. Seems the Seat belt buckle is at fault in the majority of cases.
Get it scanned and it should tell you all the codes. Why were you putting oil in? Is it leaking? Sounds like you may need to find a reputable VW mechanic in your area. There's a list on Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community - most TDI mechanics work on all dubs.
So you were totally out of oil??? Any signs of leakage? I can't imagine your engine burning that much oil???well im more worried about the check engine light. :/
oh and i noticed when i was putting oil in my engine was rreally hot and a trace amount of smoke was coming out when i took the cap off for the oil.. and my the round container where the coolant stuff is is like really brown and extremely hot when i twist the cap off. is that normal?
The container shouldn't be stained either. That means the cap isn't holding the pressure and is probably leaking some coolant around the cap which then evaporates on the expansion tank. Normally that should be white residue not brown. You may want to look at your coolant to see what color it actually is.well saturday my oil light came on, blinked and went off, sunday before i went to the beach i put some oil in it but i dont think i put enough in.. i was in a rush and my dip stick is hard to get out so i didnt even check it. my engine light came on yesterday..and today when i came back from the beach i got help from someone and checked my oil and i was low, i needed a QT so thats what i put in. its not the coolent itself its the container thats stained, its like a really nasty brown color. but i will make way to autozone asap
