Please help. crank but no start 2002 new Beetle (Bugger)
7 views 0 replies 1 participant last post by  MamasBugger
#1 ·
My wife's beloved 2002 new Beetle, 2.0, (Bugger) engine stopped at stop sign, and will not start. Towed her to shop, replaced the whole fuel system. Fuel pump, fuel pump relay, fuel pressure regulator, and fuel filter. this did nothing. then shop said that ECU not communicating with engine. check engine light and EPC light on, when ignition on. no codes at this point. we suspected a bad ECU, so we removed it, and discovered water had leaked from sunroof to ECU compartment (not a small amount of water) We completely dried compartment and ECU, and re installed it. now EPC and check engine light are off, still no start, and now getting code 01314 Engine control module: no Communication. Should i replace ECU? Please help if you can, we will not give up on her.
