add a turbo in your life!
i ejected a cd and put in a mp3 disc i have used before in the car. there was an error in reading the mp3 disc so i ejected that one. i went to try and put in a new cd and it would not suck it in. any suggestions.
thanks.
bigblock.
Dunno... that's an odd one.
I guess beside the obvious recommendation of making sure it has power, I'm not sure this is something that can be diagnosed long distance.
I can't remember... does the CD headunit have a reset button (you know... the small hole kind of in the bottom left corner of the facia... that you stick an unbent paperclip in to extracate a disc in an emergency)? I might try that... it could be that the disc drive thinks it still has a disc in it and has locked out any further loading... pushing the reset could clear that situation.
Otherwise, I'm afraid you'll have to have a tech look at it... either at the dealer or at a car audio shop. But... being that you have a 2005... seems like it should still be under warranty... so I'd probably opt for the dealer.
