My daughter's 2003 VW NB 2.0l AVH showed a check engine light. Had the codes read at Autozone: P0101, P0171 (MAF sensor, lean bank one). I figured I'd run it home, clean the MAF.
Before I got home, it just shut down. Couldn't get it started, so towed it home, did some reading.
I let it sit and tried to start it again. It cranks, briefly starts, shuts down. Brake lights work. Can hear the fuel pump kick, it'll start (VERY briefly) at different revs depending on the gas pedal depression.
Now, I don't have a laptop or any VW software or any of that.
I'm scared to disconnect the battery to clear the codes, or even the MAF to clean it because some literature says I'd need to reset engine parameters with a scan tool if I do.
Any help?
Thanks,
divebri
Any help?
Thanks,
divebri
