Hey all, saying hi and probably the first new beetle running on E85.
I've looked at the bently for service intervals but figure I might as well get input from you guys too since i don't know what the common fail points are on this motor. I'm no noob to DIY with VW's or Audis. I do have rosstech as well.
This is the parts list I have now.
ENGINE/Trans
-Lubro Moly with the billet filter housing
Volkswagen New Beetle 2.5L - MK525OILKT3 - Oil Service Kit - With Magnetic Drain Plug & Polished Aluminum Oil Filter Housing - ES#2784978
Coolant:
Volkswagen New Beetle 2.5L Engine Cooling - G013A8J1G - G13 Coolant - 1 Gallon (3.78 Liters) - ES#2603000
CTS:
Volkswagen New Beetle 2.5L Engine Cooling Temperature Sensor - 059919501AKT - Coolant Temperature Sensor With O-Ring & Clip - 4 Pin - ES#1484
Belts:
Volkswagen New Beetle 2.5L Engine Drive Belts - 07K145933E - Accessory Belt - Alternator/Water Pump - ES#2089878
Volkswagen New Beetle 2.5L Engine Drive Belts - 07K145933C - Air Conditioner Accessory Belt - ES#2748541
Ignition coils/plugs
Volkswagen New Beetle 2.5L Engine Electrical - 06E905115EK5CKTB - Ignition Service Kit - ES#2748217
Brakes/Suspension
Brakes:
Volkswagen New Beetle 2.5L Braking Service Kits - 1J0698001 - Front & Rear Brake Service Kit - ES#257354
Brake Fluid:
Volkswagen New Beetle 2.5L Braking Fluid - BF1P4 - Super DOT4 Brake Fluid - 1 Liter - ES#602
What else should I get? Valve cover gaskets? Anything you guys wish you bought before it broke? I was also thinking about changing the auto trans fluid.
