Hey guys,
I'm back with a new question
I recently took my bug in for a tune up and the mechanic told me that my oil pan is likely cracked and that my oil must be leaking. He said there wasn't much or any oil in the pan, I can't remember which but that's the general idea. I checked my usual parking spot at home and there were oil stains on the ground, they weren't too many and I don't always park there, other cars park there frequently.
The mechanic thinks the oil pan is leaking because a couple of months prior, he replaced the a/c fan control module that stopped working when I drove over badly uneven pavement at moderate speed. So I believe he made that deduction considering that incident and the low amount of oil at the time of the tune up.
I've become somewhat proficient when it comes issues with my car :lol: . I like to inform myself and learn about the problems before taking it in for a repair. It is, to some extent, normal for my car to use up oil faster (than any other car I've had). That, I have not looked much into. I don't know if the fact that it has 127,770 miles (1999 model) could factor into that? Additionally, it had a faulty catalytic converter (another uneven pavement situation) and i read online that it could lead to faster/more oil consumption than ordinary, which I then had replaced. Later, I replaced a bad O2 sensor and a symptom of a failing O2 sensor is oil exhaustion. After fixing these two problems I did notice a less frequent need for adding oil to the engine. After that, the uneven pavement that damaged my a/c followed and if the oil pan is cracked, it happened then.
Sorry for the long story but I don't want to leave anything out
The tune up was done Sept 9th (oil was filled to maximum capacity) and three days ago I checked the oil level and it was on zero so I added two quarts of oil. I may have added a quart or two between then and now but don't recall the time. And now that I'm reading this I'm realizing how long it's been since the tune-up, it really felt like it was two months ago...
I'm not sure if this makes much difference but I always use synthetic high mileage oil in my car.
So my question is, how normal does the oil consumption sound to you? And does it sound like I need to replace the oil pan?
I'm shopping around to get it replaced and of course am looking to spend the least amount possible. The mechanic that has worked on it quoted me $180 for parts and labor.
I walked into Autozone today and asked for a price check on the oil pan and they told me $59.99 and as much as I wish that was the cost for the part, I'm not sure it's the correct one.
I pulled it up online and it is this one:
Pioneer/Oil Pan (501350) | 1999 Volkswagen Beetle 4 Cylinders C 2.0L SFI | AutoZone.com
I also found this:
Dorman/Oil Pan (264-701) | 1999 Volkswagen Beetle 4 Cylinders C 2.0L SFI | AutoZone.com
If anyone here understands the difference would you mind briefing me on this please
Additional and probably repetitive details:
-1999 VW Beetle 2.0L 4 Cyl
-Tune-up in September, filled with synthetic oil-->no oil three days ago. (kind of a duh moment, but a fact :eek13
-127,770 miles as of today. My registration from 8/5/12 says 123,970 but it was very likely a guesstimate. Very likely. I've probably driven it 3,000 miles at most from that date.
If there are any more details I should provide for a better evaluation, please let me know. Thanks in advance to all who take their time to read this
I also found this:
