I just replaced the window motor on the driver side of my 02 beetle. When I plug in the motor and operate the switches it works fine, but after I turn off the key and wait a little while and turn the key back on the window motor doesn't work. I can unplug the window motor and plug it back in and it works fine until I turn off the key and turn it back on. Any suggestions
Are you actually starting the car or just turning the key on?
either way, If I start the car or just turn on the ignition switch. It acts like a relay is not resetting until I unplug the window motor. The passenger side works fine.
