I'll try to make this short. Everyone says you need 2 keys to program a key fob, and I understand why. If you only have 1 key, however, you're not screwed. Here is how to program your key fob
with only 1 key.
Materials:
1 key
1 torx t20 screwdriver
1 flat screwdriver
1 Open driver door and remove the rubber plug covering the screw for the lock cylinder.
2 Loosen but DO NOT remove this screw. If you remove it you will have to take the door apart.
3 Remove the lock cylinder from the door.
4 Insert key into the ignition and turn to the on position
5 insert the screwdriver into the lock actuator where the lock cylinder connects, turn and hold for about 10 seconds, the car should honk the horn once to indicate it is in pairing mode.
6 press a button on the key fob, the car should honk to confirm that it has paired with the key fob.
7 Turn the key in the ignition to the off position, this will exit pairing mode and complete the pairing process.
8 reinstall the lock cylinder, tighten the screw for the retainer, and replace the plug,
I have not tested this process, but I will asap. If there is any reason why this is unsafe or won't work please let me know.
with only 1 key.
Materials:
1 key
1 flat screwdriver
