2001 1.8T 97k miles. Long story short the turbo beetle took a massive hit to the oil pan from unidentified (rock) debris in the road during a massive rain storm. The hole is large enough the pan drained almost immediately I would imagine. I know exactly what could happen from such a hit so Instant emergency maneuvers were made though traffic to get off the road and shut down ASAP. At shut down there was a very audible dry running sound from turbo bearings and shutter felt though the chassis. Oil light literally flashed on the second I killed ignition. The worst part of the story is the cop that showed up and didn't want to get out in the rain said he couldn't write an accident report because it appears I was just broken down on the side of the road....insurance doesn't know what to think. What I know is I can put my fist in the oil pan and it ran with rapidly dropping oil pressure for 1-2mins at low rpm and was shut down quick essentially before oil light came on. I also know the turbo bearings sounded dry and the slight rattle and shake as she wound down was very obviouse.
What would your thoughts be on the chances that the motor is seized and or fully compromised? On a 2001 would a full engine replacement/rebuild pretty much make it totaled? Best case scenario a new oil pan and fill her back up and hope the turbo bearings aren't wasted or the rod bearings spun?
Thanks
Thanks
