Hello all!
I've been poking around these boards and reading a number of very helpful threads for the last couple of days leading up to my girlfriend's purchase of an 00 1.8T 5 spd.
We're now getting close to picking the car up (it's at a mechanic's shop in another city), and barring any snags, will be driving the car home on Saturday.
This is my girlfriend's first car, and she's wanted a lime green NB for quite some time. That said, there are a number of problems that I'm sure will require me spilling a few pints of blood to address. Though, I'm used to that with a Saab that has the most creative failures I've seen on a car... (balance shaft tensioner arm, anyone?)
The good:
-loaded 00 1.8T 5 spd - lime green w/black interior, sunroof, power everything, etc (I THINK a GLX, but not sure).
-140,000 KM (about 87,000 Miles)
-new clutch within last 1,000 KM
-new coil packs and plugs (just done this week at the shop the car is at)
-new vacuum lines, also done this week
-per the mechanic I spoke with at the shop, it runs well, and other than a few specific problems, looks like a very nice car... tight front end, good brakes, decent body and interior, etc. This is the first time the car has been to this specialist shop, and before that appears to have been maintained by a monkey - I have no history before this
The bad:
-turbo bearing leaking oil into intake, per mechanic, turbo is shot and needs to be replaced/rebuilt
-owned by a teenage girl since Aug 2012 (she burned out the clutch in a weekend... this is why it has a new clutch, and according to her father, since paying for the clutch, she has learned to drive it correctly)
-unknown conventional oil used since Aug 2012, but less than 1,000 KM since then (I suspect the turbo failure is not a coincidence)
-no idea when the timing belt and WP were done... the mechanic was starting to work on this when he discovered the turbo oil leak
We made a deal at $2,800 CAD for the car, far less than the typical price around here.
So - while there are certainly many risks with this purchase, I think it's worth it, and my girlfriend can't wait for her little green bug.
Known required work:
-change oil and filter with synthetic, ultimately will likely be Mobil 1 0w40, like my Saab
-replace turbo (or have rebuilt at local heavy equipment shop that deals with turbos)
-replace timing belt/water pump
Major risks:
-sludge damage or deposits in engine
-cat damaged by engine oil ingestion
Lower priority maintenance:
-transmission oil?
-brake fluid?
The plan now is to see the car Saturday, and if all is as expected, finalize the deal and drive the car 600 KM back home. Then, park it and not move it until turbo and timing belt/water pump are done.
My concern right now is the oil and sludge. I'm considering having the garage it's at change the oil and filter right now with some sort of fresh synthetic. Not sure that it matters if it fully meets the spec for a 600 KM drive on the highway. Are there risks here? If we did this, I'd plan to put in fresh oil and filter when changing the turbo, etc. Actually, I might seafoam it before doing turbo and timing belt, and change the oil at that point.
Any thoughts or advice to share? As I said, I'm used to ridiculous European cars and the silly things that break (seriously Saab, who puts the computerized ignition switch between the seats, by the cup holder???)
Thank you for taking the time to read this quite long winded post.
Cheers,
Colin
The good:
The bad:
Major risks:
-transmission oil?
-brake fluid?
Cheers,
Colin
