Hi Everyone,
I bought a used 2003 2.0 Auto transmission beetle for my daughter
Last weekend and when I got it home realized the 14 pin connector on the FCM was not connected. After connecting it again, the fans will not shut off after turning the car off and pulling the key.
I went ahead and replaced the FCM with one from Amazon and also ordered an OEM one also. The new FCM did the same thing. I realize it could be the aftermarket OEM, but will not know until a few more days.
So I replaced the green sensor in the coolant line which changed nothing. Replaced both fans which changed nothing. Tried pulling the triangular
plug on the bottom driver's side radiator are which changed nothing. Disconnected the AC switch on the AC pump which changed nothing.
I have a thermo switch on the way also but after reading the posts and looking, I am not sure the 2.0 had these. AIso I am not finding it. I also assume there is no relay seeing as it has an FCM.
I am at a bit of a loss. The only way I can get the fans to stop after shutdown is pull the infamous left green fuse or disconnect the 14 pin connector on the FCM.
I need some help please.
Thanks D
Thanks D
