My friend has a 99 vw beetle 1.8turbo.
The car has a lot of problems with it, but right now I am trying to trouble shoot this one:
The fans come on immediately when you crank the car up from a night of sitting in the 40 degree cold.
To start, I want to try and check the so called radiator fan thermo switch to see if its shorted, but i do not know where its located. I have read several threads on here suggesting that it is "on the radiator", but "its hard to get to".
However, her father asked a VW mechanic who according to her claims that there is "no sensor on the radiator".
Can someone confirm/deny this? Where is the sensor? Do you have any pictures??
If this is not the problem, I am going to try and test the Fan control module.
Thank you for that photo of where the fan sensor is. Ive looked everwhere but there
The 1.8t cars have 3 coolant temperature sensors. One on the coolant flange by the firewall, one on the radiator like that picture shows and one by the radiator upper hose mounted on a 3 way "Y" hose connection. i have dealt with all three and replaced the O-ring on all three.
