The quick and dirty:
Radios suck
Dedicated hardware = better
RAM iPad Floor Mount wobbles, stops pass seat from canting forward.
Solution:
Yank out radio
Install JL Audio Volume knob
Install Clarion Equalizer in glove box
Make wood block, screw a RAM Mount 3" base to it
This lets me use the 30pin connector for audio out, much better than the 3.5mm headphone jack. I get to ditch the bright radio with blinky lights, and gain a rock solid ipad mount that wont fly around and wobble when I drive crazy.
I plan to paint it black soon, maybe even fill it in and paint it white I'm not too sure.
I originally planned on a custom dash, deleting the radio + vents and putting in a ipad sized hole to slide it into, but that isn't future proof and I'd loose the vents. Before the floor mount blocked all of my fan controls, and the radio so I'd have to move that thing aside to turn the heat on or something.
The case/mount/arm is probably $60 total. I snapped the case a long time ago and used some JB weld or something to fix it which is why there's white putty all over it.
I also have a ScanGauge mounted under the emergency flasher above the cup holder, my volume knob is in the left dead button where most bugs have the seat heater controls.
The iPad isn't too high to block any windshield visibility either.
The car is a 00-TDI.
https://dl.dropbox.com/u/7917675/Car/iPad%20Side.jpg
https://dl.dropbox.com/u/7917675/Car/iPad%20Mount.jpg
https://dl.dropbox.com/u/7917675/Car/ipad%20Mount%20Face.jpg
Radios suck
Solution:
Yank out radio
