PO had the timing belt, tensioner and water pump replaced. Now the car has a rattle from 1800-2200 RPM's. Today I removed the upper timing belt cover and ran the engine, still has the rattle. Sounds like it's coming from right side.
Any thoughts would be appreciated, I'm not sure if the timing chain would make the noise only from those rpm's. It sounds like the rattle is on the outside of the engine. My first thought was a exhaust or turbo shield, but I haven't found anything loose yet.
Thanks
Thanks
