Ok.. I see from the old bulb I took out of the rear tail light, that the bulb style is #7528. Of course my local hardware store didn't have this number so upon comparing the heck out of the old bulb, and the standard 1157 double filament bulb, I couldn't see any difference.
In fact, the 1157 fit right into the socket on my beetle and works just fine.
Should I be scared? Anyone else find that a standard 1157 works just fine?
TIA
bent
Is your NB a 2003+? VW did change the bulb type for the brake lights, I'm running the same # you are in my '00.
-Des
Thanks for the info guys.. yes my NB is a 2000. I have to admit, every mechanic I know absolutely loathes VW products, so I wanted to be sure that the rear tail light assembly wasn't going to catch on fire or something because I'm using a standard North American bulb.
thanx again..
bent
Most hate them because they use non-standard ways of thinking to accomplish a task. That means more work for them, which you would think they'd like. The place that put my spoiler on, which took them 5 hours, said he won't work on another VW wihtout charging a $250 convenience fee because of how complex they are (he had to repair a broken window regulator in a 2000)
