huh?
You talkin' about upping the diameter? You'll need some caliper carriers at the least.
So far the rear upgrade that I've been interested most in is the rear vented rotors. I don't know, I think they're from a R32?
Bigger rotors alone won't do you any good though man. Gotta move the caliper to adjust.
Get in.Buckle Up.Hang on.
Ok, I get it now, you can't just slap a larger diameter rotor on the rear, you would need to replace the calipers and connected hardware too, right?
MkV Pilot
Yes. Same concept at the TT front rotor upgrade. You need to move the caliper out to accomodate the larger diameter.
