Re-Member?
Picked up a new rear seat at a junkyard cause my folding mechanism is broke.
How do I remove the rear seat in my car then? I removed the button to see if I could discern what was going on and neither of the rods feel like they're attached to anything.
Thanks!
It's pretty simple.
There is a zipper in the middle of the seat at the bottom, open that up and you'll see two bolts. Undo those bolts.
With a large flat screw driver, push down the latches on each side. When pushed down the opening will align with the pin that the seats pivot upon, and then you just pull the rear seat off.
