1 - 9 of 9 Posts
Hey guys,
Just curious on this one. My 2000 Beetle sags in the back, the car doesn't sit level. I installed new shocks that were definitely shot along with new front struts, but the front points up a bit. Plus, I have a nasty bump sound from the back when I hit a pothole. My best guess is that the rear axle bushings are shot as well. I plan on replacing them soon. My question is, if those bushings are bad, could it cause the rear to sag?
Thank you
Do you hear squeaking noises when on a bumpy road?
I'd think if the bushings are shot you'd hear a metal-on-metal sound.
Probably you need new rear springs. They are easy to change just disconnect the shock either the top or the bottom and push down on the lower spring perch with your foot and take the old spring out. The new one goes in reverse sequence though it will be harder to get in than the old was to take out. That should along with the new rear shocks you have already installed take care of your sag problem.
The clunk is likely the bushings, however when you put new shocks in did you put new upper shock mounts with those? A worn upper shock mount can cause a very annoying clunk.
Going down the road, there is squeaking. When I hit a speed bump or pothole the noise I get is very loud, almost as if the undercarriage is being hit with a big hammer. It’s very noticeable. When I replaced the shocks I did not replace the mounts. In hindsight I wish I had. Chances are I will when fix whatever this is.
When my daughter first bought her beetle, she had a noise from the rear that I could not find. The rear lower bushings looked like they were new. The only bushings underneath the car that did look new.
I actually rode in the back trunk with the rear seats down trying to locate that noise. When I finally did figure it out I found that the strut mount has a small rubber bushing inside the body of the mount and it had worn out. That noise sounded like it was coming from beside the rear passenger seat.
A bad lower bushing will sound like your rear wheel wants to fall off whenever you hit a bump.
They also have oem for more money.
Rock auto will have some less expensive alternatives. I have moog on the back of mine, they are a bit stiffer and offer a half inch to inch of extra height in the rear in addition to being cheaper.
That little item that caused the very loud and annoying noise on my daughters beetle.
I think I will just replace everything. Shock mounts, springs (and seats) and the axle bushings. It's for my daughter and I want her driving a safe car.
Thank you to everyone.
So sorry for the long delay. They just finished replacing the rear springs, upper shock mounts and the cradle bushings. The car sits level now and the awful banging noise is gone. They had trouble getting the left side bushing out and I'm betting that was the one causing all of the trouble. On the downside we had to replace a few brake lines because the fittings were fairly corroded. But better to do that now than later down the road.
Thank you to everyone who responded. Maybe someone else is having the problems I am and this helps them out a bit.
Did the rear sag cause negative camber in the rear wheels? If so, was this fixed when replacing the rear shocks and springs? I;m trying to solve this problem, where the camber of the rear wheels is off and the insides of the tire are wearing much faster than the outside. I've been searching and discovered there is no adjustment for rear camber, and the only suggested fixes I've found are replacing the whole rear axle or using after market camber adjusting plates, which might also require spacers on the calipers. I don't want to rig it with adjusting plates, and replacing the rear axle seems excessive. I'm just wondering if replacing the rear shocks and/or springs would fix the camber/sag problem.
FYI, It;s a 2000 Beetle, and quite possibly the original shocks.
Discussion Starter #9
Sorry for my delay. I don’t know about the alignment, we didn’t check it before or after. But the backend sits higher and the ride is tremendously better.
1 - 9 of 9 Posts
