Rear window issue, convertible.
171 Views 2 Replies 2 Participants Last post by  Olie3146
Hi, so I've got a 2005 convertible, I had to change the rear window regulator (I removed it with the glass still connected) it's all back in but the window isn't pushing up against the seal which is allowing the rain water to run down the inside.
Is there some sort of adjustment I can make to push the window against the rubber?
I've attached a picture but it's not great.
Automotive parking light Car Vehicle Window Automotive lighting
After regulator replacement, the windows will need to be adjusted correctly; review this video for correct adjustment procedures:
Note for anyone with similar problem, remove the rear door card, undo 3 bolts along the top of the regulator, push window outwards and then retighten the 3 bolts 👍
