My headliners doing that shrinkage thing where it's pulling back and drooping.
I could 80% fix it with pins/glue but would it be so bad to fully remove the headliner and it's cardboard/insulation? Command strip the dome lights and wires in place?
Pull the headliner out in one piece, recover it, then replace it. I could live without the headliner for a few days while I was actively replacing it but long term I wouldn’t care for no head liner.
LVM86VT
I removed the ceiling panel, removed the liner, removed the foam / glue with a wire brush. Cleaned all the rest with soapy water (gently). Let it dry. Primed it and painted it in the same color. Looks beautiful and can never ever droop anymore.
1998 NewBee TDi
Hi,
I took aluminum strap adn formed it to hold up my droopy-drawers headliner for many years and eventually had to concede defeat; depending on where you are located, I had my headliner redone by Wardell in Santa Clara, CA Wardell Auto Interiors & Tops and was able to better color-match the headliner to the rest of the stock interior. One of the things I learned from them was that the New Beetle headliner substrates is one of the best in the industry making it a favored headliner for them to replace... and as you might imagine, it ain't cheap but it will definitely last a lot longer than the OEM headliner which is notoriously cut too short causing it to go into droopy-drawers mode.
