Hi all
i have a problem with the door not opening, i have managed to undo the screws and pull the panel off enough to release the cable but the door won't release still!!
So is it possible to remove the panel with the door closed?
or any idea of how to open the door?
Cheers
It may work driver side but mine is passenger side and this side doesn't have a key hole so the I've just broke the cover.
Unless I can get the door panel off I can't see how I can get to the lock.
What makes it worse is the another metal cover.
Thanks for your suggestion, i think i will continue to search as i don't want to break the panel unless i have too!
Righto i can confirm it can come off with the door closed, if your careful but the white clip broke but they can be replaced.
I got the actuator working but i am going to replace so it doesn't happen again.
