I found a 24K mile AWP motor out of a 2003 "S" on craigslist for $1500 for the longblock. Picked it up on thursday, and ordered new waterpump with a nice brass impeller, and new timing belt parts. I put everything at TDC and maked the old belt and pulleys, then transfered those marks to the new timing belt just in case. after installing all the parts, then struggling to install the belt, finally took the tensioner back off, put the belt on, then intalled the tensioner, pulled the pin on the tensioner and hand cranked it a few times and all is good. I had to swap over the knock sensors, and crank position sensor, when I pulled the crank position sensor, some of the housing inside looked like it had been worn away or melted or both, exposing the insides, so odered a new one.
When I bought the car the head had already been taken off, unfortunately all the intake bolts are lost, so I need to get some M6x25 and nuts, and a few other various clips, nuts/bolts to replace, and one of the tubo bolt to intake manifold was broken, so had to get that removed and get a new bolt.
So now its down to how best to pull the motor, Take the front of the car, or drop down thru the bottom with a 2 post lift. I didn't see any way to get the the flex plate bolts to unbolt the engine from the tranny to try to pull it out from the top.
