Is it just a clip or an electrical connector? If it's a clip it should just pull off. Look to see if there are any locks on it that you have to push in to get it off. Also if the bolt is around the coolant hose you should use a crow foot style socket if it is stuck, you will have less of a chance of stripping the bolt.
