I was recently, dealing with a similar issue; based upon your photo, it looks like the plastic portion of the hand brake is broken off (like many VW plastics; these seem to easily break, as they age and become brittle). Mine, ended up being broken as well; in my case, I still had the broken button part left, inside my handle cover and was able to temporarily put it inside the NEW handle, so it works and I am able to use the emergency brake, it is functional. However, looking at your yours; the plastic portion seems to be missing; from what I can tell, you need to replace the whole metal lever assembly, which includes a black plastic part, that actuates the locking portion of the emergency brake. Like many VW parts; the inner plastic linkage/button, doesn't seem to be replaceable by itself but fixing the problem, requires, purchasing a whole new brake handle.
08 2.5L automatic <- Locks while siting and while driving (tho I think that's normal around 5~10 MPH?)
:/ I got something draining my battery it takes a week~ or so before it it's to low to start.
Only thing I've noticed is that doors (both) will be locked when I know I left them unlocked. So...
Hello!
Looking for input on the best (quality & cost) resource(s) for:
- Replacement HID (High Intensity Discharge) Headlight Bulbs;
AND,
- Control Modules for each side
Thank You!
Hello everyone, I’m new in this community, even though I always read the posts and find accurate solutions. However, I’m going crazy right now, here’s the thing:
I removed the center console on my wife’s 2008 Automatic (TipTronic) New Beetle to change the 12v outputs, and because the magnet on...
hi all, i have a bad lcd screen for my 2005 2.0l auto not displaying kilometers recorded, shows gears though, my cluster code is 1c920035tx. Can anyone tell me if i can only replace with this exact code or will others work
2009 2.5l convertible making loud humming sound when air is on ( sometimes). Mechanic says it’s too much crankcase vacuum after he pulled dip stick and oil fill cap and heard sucking sound. I replaced valve cover/pcv valve, and it changed nothing. When I pull the oil cap it idles rough. Any...
