1 - 10 of 10 Posts
My '99 Beetle threw its harmonic balancer down route 17 this week. Two bolts are broken in the crankshaft gear. Shall I try to extract or replace the gear?
extracting them if you can is going to be best, It takes a big tool bolted to the crank pulley to keep the crank from turning when you break the crank bolt loose.
The tool uses the 4 harmaonic balancer holes to secure itself to the crank pulley. The crank bolt is torqued to alot( I can't remember what it is but it's a bunch.
I have removed them to do crank seals with an impact gun. You need a 12 point socket and a 1/2" impact gun.
Sent from my iPhone using AutoGuide.com App
So.... who bolted the crank gear pulley on last?[/QUOTE]
Bought the car from VW Service by Ron in Daytona Beach, Florida. They have a sticker on the door stating the timing belt and water pump were replaced just prior to sale (July, 2012). So, they were the last ones in there.
Gkad you got the pieces out.
You might try a dealer for the harmonic balancer bolts My dealer intown had them instock at one dollar apiece.
Sort of pricey but I did not have to wait on shipping.
1 - 10 of 10 Posts
