Hi.
My beetle has been running a little off lately (it's actually hard to detect, but it just doesn't feel right)
I had the codes pulled at an Autozone and got the following:
P0171
P0134
P1582
Which I understand indicate a bad pre-Cat O2 sensor, bad MAF, and the 171 too lean could be caused by one of the others?
My particular question is this: If I can manage to R&R these myself will I need to do anything that requires a VAGCOM, and will I need to do something special to reset the CEL?
(I'm pretty sure I can do the MAF, the O2 I might not be able to get to, I don't have ramps or the required wrench)
My beetle's got a bunch of little issues (projects) to be done, but these need to be right before I take it out of town in a few weeks.
Thanks!
Dennis
16555/P0171/000369 - Ross-Tech Wiki
P0134 Volkswagen HO2S11 Sensor Circuit No Activity Detected OBDII Engine Light Trouble Code | Engine-Codes.com
17990/P1582/005506 - Ross-Tech Wiki
You could reset the ecu; by doing a "hard reset", removing the battery cables and touching the neg/pos cables, together for 30 seconds.
You would need to get under the car; to access the 02 sensors and rent or purchase, a special 02 sensor socket to r/r the sensor. Most auto parts stores and places like harbor freight; sell the correct socket to remove the 02 sensors.
I would check the 02 sensor and maf live data, with a scan tool; to see if they are working correctly. A fuel pressure test; would also be a good idea, just to rule that out as a possible issue (bad fuel pump).
O2
Hi.
P0171
P0134
P1582
Thanks!
Dennis
You can also rent the special wrench for the O2 sensors at your local parts store it comes in a kit with several sizes.
