This post is from the archives of URL VW TDI Repair.
The photos and text failed to upload properly. To view the complete project and 47 other how-to procedures go to the above URL.
VW service professionals show you the steps that are required to replace the rear wheel bearings on your Beetle TDI.
From the menu go to: Replace Rear Wheel Bearing on Beetle, Advanced, ID 48.
Overview
When you notice loud unusual noises coming from the rear of your Beetle, you need to act fast to avoid expensive repairs. The suspected culprit could be the rear wheel bearing. For this project, VW service professionals walk you through the repair steps so that you can Fix-It-Yourself and save MONEY on professional repairs.
Repair Steps
Step 1 - Using a flat-blade screwdriver, remove the wheel cover.
Step 2 - Use a breaker bar and 17mm socket to loosen the lug nuts on the wheel on either the drivers-side or the passenger-side of the vehicle.
Step 3 - Use a lifting device to raise the vehicle off the ground.
Step 4 - Place jack stands under the vehicle for support.
Step 4 - Remove the lifting device from under vehicle.
Step 5 - Place wheel chocks (2) under the front wheels.
Step 6 - Remove the wheel lug nuts.
Step 7 - Remove the wheel and set aside.
Step 8 - Using a 13mm box wrench or 13mm socket, remove the caliper from the rotor and set aside (See Figure 48-1).
442009__Darell's_Web_Site__Ujoints___Rear_W_Bearing_M_Fuse_Box__012
Figure 48-1 Removing Brake Caliper
Note
To prevent damage to the flexible brake hose, support the caliper with a coat hanger or wire. On models equipped with ABS brakes, turn the ignition to the "OFF" position. Disconnect the electrical connector to the wheel speed sensor.
Step 9 - Using a phillips screwdriver, remove screw (1) securing rotor to hub.
Step 10 - Remove brake rotor and set aside.
Step 11 - Using a flat-blade screwdriver, remove the hub dust cover (See Figure 48-2).
442009__Darell's_Web_Site__Ujoints__Rear_W_Bearing_M_Fuse_Box__014
Figure 48-2 Removing Hub Dust Cover
Step 12 - Using a 30mm socket, remove the wheel hub nut.
Step 13 - Using a large hammer and punch, strike the hub (Figure 48-3).
442009__Darell's_Web_Site__Ujoints___Rear_W_Bearing_M_Fuse_Box__015
Figure 48-3 Loosening Hub Flange With Hammer
Step 14 - Rotate the hammer and punch around the hub flange to loosen.
Step 15 - Position a gear puller to the hub flange
Step 16 - Secure the puller to hub flange with three (3) bolts and tighten (See Figure 48-4).
442009__Darell's_Web_Site__Ujoints___Rear_W_Bearing_M_Fuse_Box__018
Figure 48-4 Attaching Gear Puller to Hub Flange
Note
Make sure that the bolt crown in resting in the center of the axle for proper alignment.
Step 17 - Using a 11/16-inch box wrench, turn the gear puller handle "clockwise".
Step 18 - Continue turning the puller handle with the wrench until the hub flange and outer bearing can is removed.
Step 19 - Set the removed hub and outer bearing aside. Figure 48-5 shows the hub flange removed and the inner bearing race exposed.
442009__Darell's_Web_Site__Ujoints__Rear_W_Bearing_M_Fuse_Box__019
Figure 48-5 Photo of Inner Bearing
Note
A three (3) jaw puller can be used when it is placed around the hub flange for removal.
Step 20 - :Using a sledge hammer and pry bar, knock the inner race of the inner bearing away from the shoulder of stub axle so that there there is enough room for a puller to grasp the inner race.
Step 21 - Place a three (3) jaw gear puller around the bearing inner race (See Figure 48-6).
442009__Darell's_Web_Site__Ujoints__Rear_W_Bearing_M_Fuse_Box__023
Figure 48-6 Removing Bearing Inner Race
Step 22 - Using a 5/8-inch box wrench, turn the puller handle "clockwise" for removal.
Step 23 - Set the removed inner race aside. Figure 48-7 shows the inner race removed from the stub axle.
442009__Darell's_Web_Site__Ujoints__Rear_W_Bearing_M_Fuse_Box__026
Figure 48-7 Inner Race Removed
Finishing Up
Step 24 - Clean the stub axle of all foreign matter with brake cleaner and wipe dry with compressed air and a clean shop rag..
Step 25 - Apply a thick coat of wheel bearing grease to the stub axle where the bearings ride. Figure 48-8 shows the bearing hub assembly that is to be installed.
442009__Darell's_Web_Site__Ujoints__Rear_W_Bearing_M_Fuse_Box__027
Figure 48-8 Replacement Bearing Hub Assembly
Step 26 - Push the replacement hub and bearing onto the stub axle until it bottoms out (See Figure 48-9).
442009__Darell's_Web_Site_Ujoints__Rear_W_Bearing_M_Fuse_Box__029
Figure 48-9 Aligning Bearing Hub Assembly
Warning
Make sure that the hub is straight and aligned properly. A hub driven on the axle crooked will damage the bearing cage and lead to early bearing failure.
Step 27 - Using a hammer and a 2x6, drive the hub and bearing assembly until it fits inside the hub opening and mates with the inner race of the outer bearing (See Figure 48-10).
442009__Darell's_Web_Site_Ujoints__Rear_W_Bearing_M_Fuse_Box__030
Figure 48-10 Driving Bearing Hub Assembly
Step 28 - Using a large hammer and large socket (fits inside hub opening) drive the hub and bearing assembly onto the stub axle far enough so that the hub nut can be installed (See Figure 48-11).
442009__Darell's_Web_Site_Ujoints__Rear_W_Bearing_M_Fuse_Box__032
Figure 48-11 Driving On Hub Bearing Assembly
Step 29 - Use an impact wrench to install the previously removed hub nut and tighten.
Step 30 - Engage the trigger of the impact wrench and tighten the nut until it no longer moves.
Step 31 - Using a torque wrench and 30mm socket tighten the hub nut to 129 ftlb.
Step 32 - Install the dust cover that was previously removed (See Figure 48-12).
442009__Darell's_Web_Site__Ujoints__Rear_W_Bearing_M_Fuse_Box__035
Figure 48-12 Installing Dust Cover
Step 33 - Install the rotor and anchor screw previously removed.
Step 34 - Install the caliper assembly previously removed.
Step 35 - Install the rear wheel on the drivers-side or passenger-side of the vehicle.
Step 36 - Install the lug nuts onto the wheel by hand.
Step 37 - Using a torque wrench and 17mm socket, tighten the lug nuts in a staggered pattern to 89 ftlb.
Step 38 - Install the wheel cover.
Step 39 - Using a lifting device, raise the vehicle.
Step 40 - Remove the jack stands from under the vehicle.
Step 41 - Remove the lifting device from under the vehicle.
Step 42 - Remove the chocks (2) behind the front wheels.
Step 43 - Road test the vehicle.
Tools and Equipment
Flat-blade screwdriver
Breaker bar
17mm socket
Lifting device
Jack stands
Wheel chocks
13mm box wrench
Phillips screwdriver
30mm socket
Sledge hammer
Punch
Gear puller
3-jaw gear puller
5/8-inch box wrench
Pry bar
Air Compressor
Brake cleaner
Wheel bearing grease
Shop rags
Torque wrench
Overview
Repair Steps
Note
Note
Note
Finishing Up
Warning
Tools and Equipment
Breaker bar
17mm socket
Lifting device
Jack stands
Wheel chocks
13mm box wrench
30mm socket
Sledge hammer
Punch
Gear puller
3-jaw gear puller
5/8-inch box wrench
Pry bar
Air Compressor
Brake cleaner
Shop rags
Torque wrench
