I have a horn issue. I traced it around and decided it was in the steering column. I decided to take it to the dealership to get a free quote. At first he said it was the clock spring, then he came back and said it was actually some sort of tab broken off and the wiring harness from the horn that is part of the steering wheel was broken. He said the clock spring was actually good. They said to replaces the steering wheel for about $800. Then he whispered in my ear to do it myself with a used wheel.
So if I buy a used wheel that may have been in a wreck, can I just replace my air bag onto the wheel and swap them out? Do you see any issues that may come up? It looks like a straight forward job... disconnect negative terminal, turn wheel one way, push out pin, turn other way, push out pin, lift off air bag, unbolt wheel, remount wheel to proper torque, replace bag, replace pins, reconnect negative terminal.
