I finally got all the pieces gathered to replace the old head .
One thing that is not been clear is, do I use any sealant on the new head bolts when I install them?
If so what?
Its a 2004 2.0 BEV gas.
And are the timing marks aligned or not? if not then where and how do you align thme after installation? Crank first or cam first?
Ron
No NB Yellow Trifecta :(
The timing marks for the crank and camshaft should always be aligned at TDC before you take it apart and put it back together.
Certified Arcade Tech
I'm not trying to sound like an a&&. Pick up a Chiltons or Haynes manual that covers your engine. Follow the instructions TO THE LETTER regarding this procedure and you should be fine. There are no shortcuts when replacing such a major part!
In most cases (and this is where the manual will be a great help) You chase the threads for the cylinder head bolts to ensure no burrs and no rust/snot/buggers/etc... is bunging up the threads. Head bolts normally go in DRY! Nothing on them. BUT!!!! That does not apply to all engines!! For example my engine in the truck I drive: Chase out the threads, the bolts are TTY (Torque to yield)...and it's required that the very top of the bolt that contacts JUST the cylinder head seat gets a light coating of oil. That's the quirk of the engine in my truck.
But it can vary. A shop manual will provide a lot of useful information for a wide range of repairs. And it's cheap!
S-
