Okay so I am repairing my new beetle 2001 myself. The left door had some problems and I fixed it. It now works great. One problem is the right door. The right door status is:
Speaker does not work (it's not broken, it just has no electricity) - it used to before I fix the left door... What went wrong?
The red light does not work (not broken either - no electricity) - it was like this since I bought it used
The window switch works
The lock switch works but locks only the left door
So even if I did something in the left door it is not the cause of all the problems since only the right speaker stopped working after fixing the left door, the other things were like this even before.
That's it. Few more notices... Since the remote does not work I manually unlock the car. So when I put the key in the driver side only that door opens. But when I put it in the passenger side both doors open. When I press the unlock button on the driver side it unlocks only the driver side. When i press that button on the passenger side, only the DRIVER side unlocks. When I change the mirror position from the switch in the driver side only the left mirror works the right one does not. When I press the button above the unlock button in either doors it does nothing.
I doubt one of the following...
The ccm has some problems - if so how can it be fixed?
The right door has no electricity mostly (since the only thing working there is the window switch) - if so how can it be fixed?
