1 - 18 of 18 Posts
I am very new to Beetles and have come across a problem that I cannot diagnose. When I started the car this morning (it was very damp and had been raining ) it idled very rough and coughed and sputtered at anything below 2000 rpm. It was low on fuel so I added some "heat" to absorb any water due to condensation, but the rough idle still continues. I checked for codes and there was nothing present. Could this be a moisture issue in the fuel or something more?
Sounds like a crack in your coil pack. Any CEL's? Many threads on this issue. Easy change out and available part.
Franco
With the rain/moister you're having a hairline crack in your coil pack will make your Beetle do the things you're talking about with no codes. I'm almost 100% sure it's your coil pack.
Franco
Is this an expensive part or particularly difficult to change? I am relatively capable at most auto repairs, but the Beetle has me a little intimidated due to its tight engine compartment.
Try the cheapest fixes first. I had a slightly rough idle and all it was was a vacuum hose need o be replaced...namely, it was he short one right on top of the intake manifold. If it runs ok but just idles a little rough, my guess would be a vacuum leak. You can replace this yourself in about...ohhhh...32 seconds and a few dollars.
I'd change your fuel filter as well, just in case you pulled some crap through and its clogged it a bit :)
Discussion Starter #10
Just by way of an update, the car will not make power at all until the engine is warm, and then it will only make any sort of power above 2000rpm. Anything under that and the car will bog down and try to stall. I should also mention that it is a 5 speed. As long as I keep the revs over 2000 once it is warm, it will run just fine, but it chugs and sputters at every stop light and intersection.
Canadian New Member
Have you checked all your vacuum hoses and ignition wires and coil pack yet????
Discussion Starter #12
No, I have not checked the coil pack yet, but the vacuum lines seem to be okay. I hope to go over the ignition and coil pack tonight.
Discussion Starter #13
Okay, here we go with an update. Today the car popped a few codes: P0300-Random misfire detected
P0135-o2 Heater Circuit (Bank 1, Sensor 1 )
P0301-Cylinder 1 misfire detected
P0303-Cylinder 3 misfire detected
P0134-o2 Circuit No Activity ( Bank 1 Sensor 1 )
While I was poking around I found a black hose with a hole in it running to the manifold. Is it possible that this may be the culprit?
LIVE FREE OR DIE!
looks like you have some vacuum lines to replace. with those misfires i would replace the coil pack. it is under the air injector pump if equiped with it. part cost anywhere from 80 to 140 depending on brand. bought a huco from ecs tuning was 88.....solved all misfires and she runs better than ever. i had a crack down the center of the coil. just my .02 good luck!
Yep, that'd be the vacuum line on the intake manifold I was referring to. Replace that and it'll run just fine. You can take it off and take it to any autoparts store and they'll sell you a length of vacuum hose. Just cut it to length and replace it. oh you may have other vacuum leaks seeing as that one was so bad. It also looks like you may be needing to replace an o2 sensor soon as well.
Discussion Starter #16
I just wanted to say thank-you for all the help I received with this issue, this is an amazing forum, and everyone is knowledgeable and helpful. I replaced that vacuum line and the car is running perfectly fine now, going to give it an up-close look this weekend. I am very new to VW's, and not much of a motor guy, but everyone was patient and helpful, so once again thank-you. I will be on again as I plan to drive this car for a while as a driver, but would like to tune it a bit eventually.
Great...glad to hear it wasn't something more. Always check the cheapest and most obvious things first. It may not always work out that way but its better than throwing away good money...and good parts for no reason. I'd check the rest of the vacuum lines since that one was so bad. There are larger ones behind that intake area that also can go bad but the one you changed, for some reason, has a nasty effect on the cars idle if gone bad. Good luck with the car.
Well I’m from the year 2031 and I came back to this post from 2010 because my 2001 beetle is showing early symptoms but my 2025 3.5 beetle spyder is running mint. Thanks guy!
1 - 18 of 18 Posts
