21 - 40 of 43 Posts
Discussion Starter #21 (Edited)
As to the PVC valve; it looks like, you might have one similar to the 2.5L engine and it is under a black plastic cover, where the silver heat shield is on the intake manifold, on the front of the engine? I haven't worked on this particular engine and can't seem to find anything in the online service manual. You might check it out and see, if it is in fact there.
Yes. I have that on my intake manifold. I suspected that might be the pcv valve, but wasn't sure.
Discussion Starter #22
As to the breather hose; did you clean it out and see, if there is any debris, you can push out, etc? Many of the pcv hoses, get filled with oily and carbon junk; I'm not familiar with that particular hose, I would assume it would breathe, allow crankcase vapors to pass through it but I don't know for sure.
Check your PM's.
This tube looks plugged by design. Maybe because the pcv valve us a different type as you posted in another post. And I'm sure they needed to ensure the port of the valve cover was plugged.
Sent from my SM-N975U1 using Tapatalk
Discussion Starter #24 (Edited)
Here are some pics that I took today. I'm sure the top looks familiar.
Odd that it has a connection to the inside of the intake manifold. It attaches to a metal piece that moves in and out. What in the world is this inside the intake?
Hmm, good question; again, I haven't worked on that particular engine code 2.0L but I am not seeing a spring/diaphragm combo, like the 2.5L has above? I wonder, if that is the pcv; inside the intake port, when you removed the plastic cap?
Discussion Starter #28
Oh, I forgot I to take a picture of the spring. It was between the black cap and the diaphragm.
Discussion Starter #31
Here are a few other pics that I had to post separate.
Pic of my inspection camera
I guess, they call it a "change over" (valve)? Vacuum Testing procedure; shown in the service manual:
Engine codes BDC, BGD
Intake manifold change-over valve -N156-
8. Intake Manifold Tuning (IMT) valve -N261
Very unique setup; I don't know, if they have a repair kit for that, the testing pages, indicated to replace the whole intake, if the valve was defective. How does the diaphragm look, any damage and is the linkage on the back, broken or does it connet, to the internal link ok? I guess, you could do the vacuum pump test and see, if it operates correctly or has a vacuum leak.
Discussion Starter #38
Ok, this part was supposed to be the pcv valve, but now I guess not. All these parts can go back together as there is no known issue. I still would like to know what the mechanical parts are for inside the lower intake manifold.
variable intake manifold actuator (arrow) off intake manifold change-over valve -1-.
Note: The variable intake manifold change-over actuator is integrated in the manifold and is therefore not visible from the outside.
Sounds like what they call it; underlined above. I would test it and make sure; it doesn't have leaks and actuates as it should? Got a Mityvac vacuum pump tester or equivalent, to test the vacuum?
Testing procedures:
Discussion Starter #40
Did you clean it, replace the gasket, (you did that already) and do the throttle body alignment procedure?
Well, just to be sure, I pulled the throttle body to make sure I cleaned it as good as I thought I did.
Oddly, there was no gasket, but I think this used a rubber seal.
Received and setup VCDS , but the throttle body is still off as well as the air box.
21 - 40 of 43 Posts
