Ethan, I had s bit of an issue getting the SAI out. It would only slide so far, then it butted up against some fluid reservoir that I haven’t identified yet. ? I unbolted the reservoir, moved it to the side a little an was able to swap out thr SAI without much of an issue.My situation is a bit different in that I was trying to access the coils beneath this. I was barely able to squeak the SAI pump out without doing more than disconnecting the hoses and the electric plug.
The wiring for the pump from the plug into the unit was kind of stiff and made getting it out a bit of a challenge. It comes out, though.
