Hello All
I have a 2006 New Beetle TDI with 102,000 miles on it that I bought from a friend last year (with 98,000 mi.). The tires were in good shape but I just noticed when rotating the tires last weekend that both of the back tires are badly scalloped on the inside tread.
The air pressure in the tires matches the data tag on the door that has the front tires at 35 psi and the rear at 39 psi which seems like the maximum load rating pressure for the rear. I use this car to drive to work and never haul anything other that my 170# self. My question is would 39 psi be too high for normal driving causing the unloaded rear end to bounce and scallop the tread. I am also considering replacing the rear shocks.
Thanks Steve
Thanks Steve
