So my wifes beetle has the P0411 code. I've checked everything, the pump runs good if its hooked up to power, the hoses are good, im assuming the combi valve is good. The issue seems to be electrical, the relay passes a bench test, and if I hook up a jumper wire in the relay box the pump does run, but the pump doesn't run when you start the car with the relay in place so the PCM can run it. What am I missing here? help please haha
